• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    JamaL9722060
    Accepted Solution
    Is there a way to show the last number of the dimension length as 5 or 0?
    119 Views, 5 Replies
    03-14-2012 10:44 AM
    I want to show the unit in mm with precision (decimal places) equal zero such that the and to force the last number as 5 or zero
    For example, I need to display the 7554mm as 7555 and the 7558mm as 7560
    Is there a way to do that?
    Thank you for the help,
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Distinguished Contributor
    Re: Is there a way to show the last number of the dimension length as 5 or 0?
    03-14-2012 11:51 AM in reply to: JamaL9722060
    Using the DIMSTYLE command, pick the style you want to modify and then set up precision to be 0.0 and round off to be 0.5.  Hope that helps!
    *Pro
    nestly
    03-14-2012 12:33 PM in reply to: jwjones1
    I think it would be Precision = 0.0000 and Round Off 0.0005
    .... and don't forget to uncheck Trailing Zero Suppression, if you always want to show 4 decimal places..
    03-14-2012 12:45 PM in reply to: nestly
    Whoops!  Just reread the problem.  Yes, precision set to 0 but I think the roundoff should be 5, right?  He's looking for whole number increments of 5.
    *Pro
    nestly
    03-14-2012 12:52 PM in reply to: jwjones1
    LOL.... I totally mis-read it also....
    JamaL9722060
    03-14-2012 03:51 PM in reply to: jwjones1
    Thank you guys for the help. it did work.
    best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
