AutoCAD 2010/2011/2012 DWG Format
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Interconne cted linear parameters
Options
- Highlight
- Email to a Friend
119 Views, 1 Replies
11-12-2012 08:37 AM
Hi! I have created a simple L-shaped dynamic block with a lookup table for its height and length. In addition to the ability to pick the right value pair using lookup table (HxW) I have added the ability to stretch the height or length using a stretch grip and a list of values. Is it possible to make the length automatically adjust to a corresponding value from the lookup table if the height is changed and vice versa? Thanks in advance!
Re: Interconne cted linear parameters
Options
- Highlight
- Email to a Friend
11-13-2012 11:15 AM in reply to:
viktors.zilinskis
I think you're looking for a block properties table. That has the option of forcing the parameters to the desired values.
(if ("mysolution"=answer) then (click "Accept As Solution"))
Brandon Gingerich
Brandon Gingerich
