AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Importing .sat/.igs/ .step files into AutoCAD 2011 Educationa l
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am trying to import .sat files into an educational version of autoCAD 2011. I am using the import command and selecting the .sat format selecting the file and then I am getting "Unable to read the ACIS file E:\001904 GS PM_2.SAT"....any suggestions?
Re: Importing .sat/.igs/ .step files into AutoCAD 2011 Educationa l
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
what version does the SAT-file have?
Reading the help brought my to my first tip: AutoCAD 2011 does support SAT-files versions up to 7 (>>>details<<<).
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
as indicated - Autodesk products will open ACIS (*.sat) files up to v7.
For *.igs or *.step or *.stp you would need a later version of AutoCAD or you could use the FREE
Inventor Fusion http://labs.autodesk.com
You can check the version of an ACIS (*.sat) file by opening in Notepad and check the first or second line.
Search for download of Hoops ACIS Viewer if you need to convert from a later version of ACIS down to v7.
The menu location in Hoops to convert down to v7 is not where you might expect it to be - so look around.
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am actually not sure what version .sat file it is......it was given to me by a third party and checking properties gives me little to no info.....the file is attached....any ideas?....Thank you for the help....actually this forum will not let me upload the .sat file.......
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
wow ok didnt read this before replying, thanks for the help!!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So I opened the .sat file in notepad (see attache jpg) and it appears that it is version 19?....however in AutoCAD when going import>acis> then selecting file I still get....."import Unable to read the ACIS file E:\001904 GS PM_2.SAT".....???
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
danielsm wrote:... I still get....."import Unable to read the ACIS file E:\001904 GS PM_2.SAT".....???
You must have missed the point that Autodesk products only read up to v7 ACIS, so of course AutoCAD is not going to read a v19 ACIS file.
You will need to use something like Hoops ACIS Viewer (search Google) to convert down or ask the source to set the save Option to v7 or ask the source for a STEP (*.stp) file or *.dwg.
If you attach the file here - I will convert it for you.
First you must right click on the filename and select Send to Compressed (zipped) Folder, and then attach the resulting *.zip file here.
