• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    Image Display order in diferent views
    250 Views, 3 Replies
    10-25-2012 04:33 AM
    Dear Sirs,
    I have 2 images that I need to see on 2 diferent views. On one view I need to see image A over image B. On the other view I need to see image B over image A. When I do the display order, it reflects on both views, so I have the same order on both views.
    How can I avoid this, so that I can see different display orders depending on the view?
    Hope I was clear enough.
    Regards
    Ricardo
    p.S I am usinf AutoCAD 2010.
    Please use plain text.
    Re: Image Display order in diferent views
    10-25-2012 05:18 AM in reply to: ricardomartimcruz
    reference image A twice, on different layers. Within the viewports you can then freeze (viewport-freeze) layer A1 and in the other A2. In the draworder you can then set A1 under B under A2
    HTH, - alfred -
    Alfred NESWADBA
    Member
    10-25-2012 07:46 AM in reply to: ricardomartimcruz
    Hello Alfred,
    thank you for your answear.
    However I am using viewports on model space. ( Set Viewports -  Two: Vertical).
    In former versions of CAD I was able to do it, because when I made the draw order, only one viewport would refresh. Then I got 2 viewports, one with one image on top, the other with the same image below.
    Should there be any kind of system variable to do that?
    Any help would be appreciated.
    Ricardo
    10-25-2012 08:18 AM in reply to: ricardomartimcruz
    You may play with sysvar SORTENTS (>>>details<<<), but I would then switch to a layout with viewports instead of tiled modelspace (e.g. for 3D-construction I have a layout not for printing, just for construction and that works very well).
    - alfred -
    Alfred NESWADBA
