• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    M_Mogharabi
    Accepted Solution
    How to print dwf file
    941 Views, 7 Replies
    12-18-2011 02:04 AM
    I want to print an existing dwf file to printer in a network programmatically with c# code. I tried acdbmgd.dll and acmgd.dll but i did not know which class and method should i use.
    please help me...
    Please use plain text.
    *Expert Elite*
    Re: How to print dwf file
    12-18-2011 01:18 PM in reply to: M_Mogharabi
    Hi,,
    if you really mean DWF (and not DWG) then you should look either in the >>>forum for DesignReview<<< or, if the DWF is loadable in your Internet Explorer then you should look into the IE-lib for printing.
    The acdbmgd.dll and acmgd.dll are AutoCAD-libs and are not used to print a DWF as long as you don't want to insert it into an AutoCAD-drawing and do a plot then from AutoCAD (what's a long way round).
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Active Contributor
    M_Mogharabi
    12-18-2011 09:24 PM in reply to: alfred.neswadba
    Thanks alfred, first I have searched a week to find a way to print DWG file but i did not find anything and just i found some applications to convert DWG to DWF. so i thought that i should convert my DWG file to DWF and then print the DWF file.
    Is there any way to print DWG file directly with c# code??
    Please help me...
    *Expert Elite*
    12-19-2011 12:08 AM in reply to: M_Mogharabi
    Yes, there exists a lot of code around the world, e.g. >>>this from Kean Walmsley<<<
    - alfred -
    Alfred NESWADBA
    Active Contributor
    M_Mogharabi
    12-19-2011 02:10 AM in reply to: alfred.neswadba
    Thanks alot. however that code is for DWF files(not DWG files), so i should convert my DWG file to DWF before start to plotting it, am i right?
    *Expert Elite*
    12-19-2011 02:38 AM in reply to: M_Mogharabi
    No, not in the way you mean. The code shows how AutoCAD has to be used for plotting via C# (plot a DWG).
    And that you think it's for DWF (because in the code the word "DWF" appears) ==>the code's result is a "plotted DWF-file", but you can change the code to plot to any other plotter, just set it to your plotter- (and page-) -properties.
    - alfred -
    Alfred NESWADBA
    Active Contributor
    M_Mogharabi
    12-19-2011 08:49 PM in reply to: alfred.neswadba
    ahaa... Thanks alot again. now i am got it. excuse me for my beginner questions, but it is the last one :
    How can i change the plotter from file to printer? How should i change the string parameter of "SetPlotConfigurationName" method  to send my DWG file to printer?
    *Expert Elite*
    12-19-2011 11:16 PM in reply to: M_Mogharabi
    look to the PC3-files you have plus the paper-sizes defined for each plotter. You can therefor start AutoCAD, open the _PLOT-dialog and there you have the info what is configured on your machine and so what's ready for use.
    - alfred -
    Alfred NESWADBA
