AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
How to print dwf file
- Highlight
- Email to a Friend
I want to print an existing dwf file to printer in a network programmatically with c# code. I tried acdbmgd.dll and acmgd.dll but i did not know which class and method should i use.
please help me...
Re: How to print dwf file
- Highlight
- Email to a Friend
Hi,,
if you really mean DWF (and not DWG) then you should look either in the >>>forum for DesignReview<<< or, if the DWF is loadable in your Internet Explorer then you should look into the IE-lib for printing.
The acdbmgd.dll and acmgd.dll are AutoCAD-libs and are not used to print a DWF as long as you don't want to insert it into an AutoCAD-drawing and do a plot then from AutoCAD (what's a long way round).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
Thanks alfred, first I have searched a week to find a way to print DWG file but i did not find anything and just i found some applications to convert DWG to DWF. so i thought that i should convert my DWG file to DWF and then print the DWF file.
Is there any way to print DWG file directly with c# code??
Please help me...
- Highlight
- Email to a Friend
Yes, there exists a lot of code around the world, e.g. >>>this from Kean Walmsley<<<
- alfred -
Alfred NESWADBA
- Highlight
- Email to a Friend
Thanks alot. however that code is for DWF files(not DWG files), so i should convert my DWG file to DWF before start to plotting it, am i right?
- Highlight
- Email to a Friend
No, not in the way you mean. The code shows how AutoCAD has to be used for plotting via C# (plot a DWG).
And that you think it's for DWF (because in the code the word "DWF" appears) ==>the code's result is a "plotted DWF-file", but you can change the code to plot to any other plotter, just set it to your plotter- (and page-) -properties.
- alfred -
Alfred NESWADBA
- Highlight
- Email to a Friend
ahaa... Thanks alot again. now i am got it. excuse me for my beginner questions, but it is the last one :
How can i change the plotter from file to printer? How should i change the string parameter of "SetPlotConfigurationName" method to send my DWG file to printer?
- Highlight
- Email to a Friend
look to the PC3-files you have plus the paper-sizes defined for each plotter. You can therefor start AutoCAD, open the _PLOT-dialog and there you have the info what is configured on your machine and so what's ready for use.
- alfred -
Alfred NESWADBA
