AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
How to keep the “center mark” at the center of the circle or arc?
- Highlight
- Email to a Friend
- Report Inappropriate Content
I wanted to keep the “center mark” at the center of the circle but sounds not to work!
Is there a way? Or do we need to draw it using the “point” command?
Thank you for the help
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Re: How to keep the “center mark” at the center of the circle or arc?
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Not for object-snap, if you have more osnaps active than "center".
If you need it very often I would create a block with a circle (radius = 1) and a point in the center, then create a block from these two objects and for every position you want to have a circle you can now insert this block with a scaling = radius.
It's a workaround, because it does not give you the mass of construction-options like TAN-TAN-RADIUS or PNT-PNT-PNT or ..., it also can't be trimmed without beeing exploded.
You can also use your idea with point (without building a block), but then your point should be "connected" via constraints to your circle-center.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
Draw a point in the center of the circle, use geometric constraint to constrain the point to the center of the circle. After you do this, move the point, the circle moves. Move the circle, the point moves.
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
- Highlight
- Email to a Friend
Thank you guys for the very useful ideas that you have provided. This answers my question.
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
