• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    JamaL9722060
    How to have more than one point style in the same file?
    566 Views, 6 Replies
    04-23-2012 01:06 PM
    I’m wondering if there is a way to have more than one point style in the same file?
    Is that possible?
    Thank you for the help
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: How to have more than one point style in the same file?
    04-23-2012 01:08 PM in reply to: JamaL9722060
    Only one at a time in a file: sounds like you are in dire need of a 'points' symbols library.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    JamaL9722060
    04-23-2012 02:25 PM in reply to: pendean
    Many thanks.
    The point style should be like other styles (dimension, text, table, leader, etc)
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
    *Expert Elite*
    heinsite
    04-23-2012 10:38 PM in reply to: JamaL9722060
    Dean is correct here, Jamal.  Points are created by a variety of commands in AutoCAD including the POINT command, MEASURE and DIVIDE.  As such, a point is really what I'd call a "utility" object.  It's not intended to be a permanent part of a drawing.  Points are generally either temporary or included only on a layer like DEFPOINTS, or another that never plots.  If you do have use for something like a point in your drawings, create dedicated blocks for them and stash them on a custom tool palette with their standard layer(s) preset.
    Dave.
    Dave Hein, P.E.
    Distinguished Mentor
    Moshe-A
    04-24-2012 12:48 AM in reply to: JamaL9722060
    Jamal hi
    Does custom linetypes can accomplish your need?
    Moshe
    *Expert Elite*
    pendean
    04-24-2012 05:18 AM in reply to: JamaL9722060
    I take it you've never zoomed out, then REGENALL, and watch your custom point shapes explode in size yet? Your inexperienced CAD-life is in for a shock :smileyhappy:
    You are barking up the wrong tree with this idea: if you want something permanently displayed, you need to create a custom object (block is ideal in this case) to display it at the size and shape(s) you need. DIVIDE and MEASURE commands can use blocks instead of points, get creative and take control of your drawings.
    JamaL9722060
    04-24-2012 02:33 PM in reply to: pendean
    Many thanks guys for the comments. They are quite valuable. Best Jamal
    Firefox 20.0,
    Kaspersky 2013.
