• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    How do you turn off the layout tab preview?
    162 Views, 8 Replies
    01-31-2013 06:29 AM
    We just received ACAD 2012 and I would like to turn off the layout tab preview option/function. We have drawings with upwards fo 60-70 layout tabs in them and the preview is annoying and is causing some issues. I can't seem to find the system variable to trun it off.
    Any input is appreciated.
    Thank you.
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: How do you turn off the layout tab preview?
    01-31-2013 07:05 AM in reply to: herdbull
    Unfortunately there is no option to turn it off.
    Active Member
    02-01-2013 04:41 AM in reply to: herdbull
    Hmm..... this is very unfortunate as it's nothing but a video hog and due to the preview it doesn't scroll through the layout tabs efficiently. Once again forced to use what big brother "thinks" we want with no way of turning it off :smileysad:
    *Expert Elite*
    pendean
    02-01-2013 06:53 AM in reply to: herdbull
    AutoCAD relies heavily on the built-in Thumbnails: you choice to turn it all off may speed up your session, but that means all preview thumbnails are off.
    UPDATETHUMBNAIL=0
    CAPTURETHUMBNAILS=0
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Member
    02-01-2013 07:02 AM in reply to: pendean
    Thank you.
    I changed the settings but it did not affect the Layout tab preview. It is still there.
    *Pro
    02-04-2013 06:04 AM in reply to: herdbull
    Are you referring to the "Quick View Layouts"?  If so, simply click on the "X" to close it out (it's at the bottom center of your screen just under the preview windows), or, enter the command QVLayoutClose
    Active Member
    02-04-2013 06:10 AM in reply to: murray-clack
    Thank you, but QVLayoutClose does nothing. When hovering over the layout tabs the preview still activates. Also I have no "X" at the bottom center of the screen below the preview windows.
    *Expert Elite*
    pendean
    02-04-2013 11:07 AM in reply to: herdbull
    I think we've determined that what you seek is not something you can turn off. FYI, it's still in 2013 unchanged.
    Are you running in Windows XP by change, or a minimum-spec Win7 PC?
    Active Member
    02-04-2013 11:12 AM in reply to: pendean
    I believe that may be a correct statement. Im running into road blocks everywhere I look.
    We are STILL running Windows XP (sigh) no upgrade planned until 4Q13. Then all the real fun will begin.
