• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Mentor
    Re: How do you get the old Array style back?
    04-20-2012 07:23 AM in reply to: BrianS82
    I do agree with you about the Ribbon being a pain.
    I use the Ribbbon only because with each new Release, the current becomes the old.
    Then the first "old" gets replaced by the new "old".
     Someday soon, only the Ribbon will remain.
    BUT GOOD NEWS.
    Type "H" for "Hatch".
    Then type "T" for "sTettings".
    The old dialog box will appear.
    Read Ya Later -Cliff
    Please use plain text.
    Distinguished Contributor
    05-02-2012 06:58 AM in reply to: rkmcswain
    .ah-hahhhh......throws out another one
    ViewCube......you need to type Navvcube to turn off.......s/b vcube or something more intuitive
    :smileyhappy:
    Member
    simma81
    07-23-2012 06:24 PM in reply to: BrianS82
    Thanks a lot...!:smileyhappy: its worked for me. and easiest way too..!
    Rajasimman.R
    Member
    simma81
    07-23-2012 06:29 PM in reply to: simma81
    This is the easy method...Lol..! and its worked for me..! Thanks..!!!
    Rajasimman.R
    Hi Brian;
    I had the same frustration with my acad 2012 version...
    If you have a previous acad version (I used my acad 2011 version) there is a simple solution...:smileyhappy:
    Just copy AcArray.arx and AcArrayRes.dll  from a previous release and copy them to your acad 2012 folder, replacing the new ones. (for save reasons first backup the original 2 acad 2012 files..).
    Normally you'll find the files in this folder C:\Program Files\Autodesk\AutoCAD 2012 - English.
    Launch acad 2012.
    In the command line just type array and your "old window style" will return.
    If your an advanced user, just make a button for it or remap the arrayrect to array.
    I hope this will "fix" your "frustration"
    Regards
    Kamers Bart
    Aannemingen Verelst Betonbouw
    Member
    10-08-2012 12:36 PM in reply to: BrianS82
    arrayclassic
    Don't forget to change it in the .pgp file so it maps to the same keystroke.
    Try that.
    New Member
    Granthg
    12-14-2012 08:00 AM in reply to: BrianS82
    The command for the old array dialog box is arrayclassic
    AllenJessup
    12-14-2012 08:45 AM in reply to: BrianS82
    I haven't done any testing. But you might be able to get it by using INITCOMMANDVERSION.
