• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    BrianS82
    How do you get the old Array style back?
    4116 Views, 26 Replies
    06-02-2011 12:49 PM
    My company just got all new computers and upgraded out AutoCAD to 2012 from 2009. And every single drafter has complained to me that the new Array is terrible. Basically, it seems to take 10 times as long to set up and array as it used to and now it's linking all of the objects together as a group which is absolutely terrible for what we do especially when we are making 4 or 5 columns or hundreds of objects. I cant find any classic or legacy array commands. This really needs to be put back in because right now everyone is asking us to put AutoCAD 2009 back on the computers, and the whole reason we bought new PCs is because they couldn't run anything after 2009 without being too slow to be productive. Thanks for any help.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: How do you get the old Array style back?
    06-02-2011 12:56 PM in reply to: BrianS82
    Explore a nearby discussion on the topic, there is nothing new to add unfortunately:
    http://forums.autodesk.com/t5/AutoCAD-2012/where-is-the-array-dialog-box/td-p/2999910
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    *Expert Elite*
    GrantsPirate
    06-02-2011 06:14 PM in reply to: BrianS82
    This won't help with the lack of dialog but you can use
    -Array to get the classic non-dialog array and it won't make it associative.
    *Expert Elite*
    rkmcswain
    06-03-2011 06:53 AM in reply to: BrianS82
    BrianS82 wrote:
    ....I cant find any classic or legacy array commands.
    Take a look at: http://www.cadnauseam.com/products/classicarray/
    Distinguished Contributor
    06-03-2011 01:15 PM in reply to: GrantsPirate
    I created a new "-array" button for my Ribbon and Tool Palette. Just titled it Simple Array. Makes things a heck of a lot easier for my purposes.
    Member
    06-22-2011 08:41 AM in reply to: BrianS82
    Hi Brian;
    I had the same frustration with my acad 2012 version...
    If you have a previous acad version (I used my acad 2011 version) there is a simple solution...:smileyhappy:
    Just copy AcArray.arx and AcArrayRes.dll  from a previous release and copy them to your acad 2012 folder, replacing the new ones. (for save reasons first backup the original 2 acad 2012 files..).
    Normally you'll find the files in this folder C:\Program Files\Autodesk\AutoCAD 2012 - English.
    Launch acad 2012.
    In the command line just type array and your "old window style" will return.
    If your an advanced user, just make a button for it or remap the arrayrect to array.
    I hope this will "fix" your "frustration"
    Regards
    Kamers Bart
    Aannemingen Verelst Betonbouw
    Member
    06-22-2011 08:45 AM in reply to: BrianS82
    Hi Brian;
    Launch acad 2012.
    Regards
    Kamers Bart
    Valued Mentor
    TrevN
    06-23-2011 02:34 AM in reply to: Kamers_Bart
    Old dogs and all that!!  :smileywink:
    Valued Contributor
    07-08-2011 06:06 AM in reply to: Kamers_Bart
    Awesome!  Should have thought of that myself!  Thanks!
    07-19-2011 07:48 AM in reply to: Kamers_Bart
    Hi ......sounded like a great work around, but this did not work for me.....I do not get the the old dialogue box.
    If I typre Array, I get no response and the Command line is blank, awaiting the next command ie it is as if ACAD has never heard of ARRRAY.......... using -ARRAY still works
    any sugestions?
    thanks
    Randy
    "Never go with a hippy to a second location"
    J. Donnaghey
