• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    mattsears18
    How can I calculate cut and fill?
    1232 Views, 2 Replies
    07-14-2011 06:17 PM
    I've used autocad for a while, but I've never created surfaces or anything. Right now I'm using autocad 2011, but I can get civil 3D if need be.
    I have a file with existing contours and proposed contours. How can I make 3d surfaces and calculate the cut and fill?
    Many thanks!
    Please use plain text.
    Member
    engqld
    Re: How can I calculate cut and fill?
    07-14-2011 08:58 PM in reply to: mattsears18
    The way I would do this would be by creating the two surfaces in AutoCAD Civil 3D both being a Tin Surface with the appropriate elevations as per the countour heights. Once you have both surfaces you can then create a Tin volume which you set a base and comparison surfaces once this is created under go to surface properties - statistics - volume this will give you a cut fill and net volume.
    Hope this helps
    Distinguished Contributor
    07-15-2011 07:09 AM in reply to: engqld
    LOFT command can also come in handy for these types of calculations.
    3D AutoCAD Pipework - http://www.HerculeDesign.com/
