• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Member
    Accepted Solution
    Help with Burst command
    342 Views, 2 Replies
    07-27-2012 05:56 AM
    I am running AutoCAD 2012 Electrical.  The source wiring diagrams I am working with have attributed blocks all over the drawing.  For my purposes, I dont need to export the data, but I do need to change the drawing.  When I use "Burst" or "Explode Attributes to Text" in the Express Tools menu, it does change the attributes to text. However, it throws all the data that is in in the attribute all over the face of the drawing.  This is extremely time consuming to delete them as some are micro small text.
    I need a command that will explode the attributes to text, turning the blocks into entities, as if there are no blocks at all.
    Can someone help find a solution?  I have hundreds of these to do.
    thanks for any help!
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Help with Burst command
    07-27-2012 07:26 AM in reply to: jleeport
    You can try iBURST from Lee Mac to see if it'll make any difference.
    http://lee-mac.com/upgradedburst.html
    Member
    07-31-2012 11:05 AM in reply to: Patchy
    Patchy, thanks for the suggestion and providing a link. I follwed the link and got the .lsp file which worked perfectly!
    thank you for your time!
    jlp
