• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor lai
    lai
    Hatch editor not function when double click
    4367 Views, 6 Replies
    03-27-2012 07:48 PM
    Need help..I can't edit my hatch pattern when i double click it.I only able to edit the hatch patter once after i click the "hatch editor" menu button. Please advise.
    Please use plain text.
    Valued Contributor
    Re: Hatch editor not function when double click
    03-27-2012 08:06 PM in reply to: lai
    Two thing:
    1. Are you see the editor in the ribbon when in 2D drafting workspace?
    2. Is your PICKFIRST system variable turned on (set to 1) or turned off (set to 0)?
    Valued Mentor
    gjrcmb
    03-27-2012 08:28 PM in reply to: lai
    From what I am gathering you want to Hatch Edit dialog box to display when double clicking an existing Hatch pattern.  Right now when you double click a hatch pattern the Quick Properties dialog box opens.
    Seems as though you Double Click Action in the Customize User Interface is set to Quick Properties and that you need to replace that action with HatchEdit.
    See Overview of Double Click Actions and the section "To modify a double click action".
    In Step 3 find the "Hatch" item and click the plus sign.  It probably says Quick Properties under Hatch at this point.  If so continue.
    Skip step 4.
    In Step 5, type Hatch into the Search Command List, and then drag one of the Hatch Edit entries from the Command List to the Hatch item under the Double Click Actions, which should replace the Quick Properties.
    Click OK to close the Customize User Interface, and test out a double click on a Hatch pattern.
    Gavin Rouleau, PE
    C3D 2012 SP1, Win XP Home
    lai
    03-27-2012 08:55 PM in reply to: lai
    Thanks for the help..this is just what i needed....
    New Member
    08-20-2012 10:31 AM in reply to: lai
    I've completed all the steps, and even when I go back and check in the CUI it shows Hatch Edit under the Hatch option; but when I double click on a hatch it's still giving me the quick properties! so annoying!
    I tried re-starting the program. still nothing.
    any suggestions?
    Distinguished Mentor
    08-20-2012 02:09 PM in reply to: MissBianca
    You can change your Quick Properties setting with the QPMODE command.  Enter 0 (zero) to turn it off.  If you like it on, try setting it to either 1 or 2.
    New Member
    08-20-2012 02:12 PM in reply to: dmfrazier
    gah! that didn't work either!!
