• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    MatthewB80097
    Hatch Select objects
    926 Views, 5 Replies
    08-09-2012 06:51 AM
    Recently started using autocad in ribbon mode
    Is it possible with the hatch command to be able to select objects first instead of picking an internal point?
    I looked at this thread first which covers the same problem but not sure if there ever was a solution
    http://forums.autodesk.com/t5/AutoCAD-2011/hatch-dialog-box/m-p/2684880/highlight/true#M2018
    HPDLGMODE is currently set to 2, I tried setting it back to 1 but that brings up the hatch popup window as it does in Classic mode and 0 does the same thing as 2.
    Please use plain text.
    Valued Mentor
    Valued Mentor
    sjg
    Re: Hatch Select objects
    08-09-2012 12:34 PM in reply to: MatthewB80097
    When in hatch command, look at your command line. Just hit S, for select objects. Easy as that.
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    Valued Contributor
    MatthewB80097
    08-10-2012 12:36 AM in reply to: sjg
    Yes I know that, however I prefer to keep my area hatches seperate so therefore I have to hit S everytime which means I have to hit H then enter then S then enter, ideally I would just like to hit H and then enter, enter, enter etc. I want the default to be select object not internal area if possible and was hoping that there may be a system variable.
    Valued Contributor
    MatthewB80097
    08-10-2012 02:56 AM in reply to: MatthewB80097
    Oh and also I want all my hatches to be seperate  & not one hatch object with multiple boundaries in case I have to remove certain sections later on
    Valued Mentor
    08-10-2012 04:00 AM in reply to: MatthewB80097
    Have you thought of using a macro, assign it in a toolpallete, then select your objects hit the toolbar (or shortcut key) once, and move on to whatever is next.
    You can set hatch type, scale etc even the layer it goes onto. Even create different macros for often used hatch types.
    For example ^C^C-hatch;s;p;;a;h;;;; places the current hatch type in your prior selected objects and creates seperate hatches.
    Steve
    Regards Steven Gray
    Setting Out (Joinery Manufacturing)
    Autocad 2013LT
    Windows 7 professional
    SugarCAD
    08-10-2012 04:53 AM in reply to: MatthewB80097
    Try HPSEPARATE=1
    Controls whether a single hatch object or separate hatch objects are created when operating on several closed boundaries.
    0 - A single hatch object is created
    1 - Separate hatch objects are created
