AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Hardware Accelerati on
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The next version will be one for mac, but at the moment i have my version 2012 for windows.
So I'm using bootcamp.
In my opiniun it's only a driver witch is missing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you tried rolling back your driver?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The Intel HD series of cards all have the same model number. The only integrated version supported is the version for workstations. All other versions are laptop cards. Our testing shows the workstation card to be certified, but the laptop cards are not. Unfortunately the workstation version was tested and certified first. The older certified hardware list shows that model as being a certified card. Since there is only 1 model number, the software cannot differentiate between flavors. The laptop versions are not certifiable. There are more laptop versions than the workstation version. In 2011 Update 1.1, we changed the Hardware Certification List to reflect the current status of that model number to reflect the more common versions. It is no longer certified, and therefore Hardware Acceleration is disabled. Our developers are aware and working on this issue.
Joshua Benoist, PE
Senior Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sounds like the best option for the OP is to purchase a certified card.
I don't believe the entry level Nvidia for Mobile is prohibitevly expensive.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My Intel HD Graphics card has a different model number than what is listed in the AdskHwCertificationDatabase.xml.
I am using an early 2011 MacBook Pro, 13" model. I boot into Windows 7 using Bootcamp. I am using Autodesk Product Desigb Suite 2012. Autodesk Inventor Professional 2012 recognizes the card and enabled hardware acceleration, but AutoCAD Mechanical 2012 does not.
Pulled from Device Manager
- Device Description: Intel(R) HD Graphics Family
- Hardware Id: PCI\VEN_8086&DEV_0126&SUBSYS_00DB106B&REV_09
- Vendor: 32902
- Card Id: 294
From AdskHwCertificationDatabase.xml
- Name: Intel(R) HD Graphics Family
- Vendor: 32902
- Card Id: 290
There are no AlternateId's specified for the 290 <card> XML element within AdskHwCertificationDatabase.xml.
Am I understanding you correctly, that you're saying that the issue is simply that the required XML entry into the AdskHwCertificationDatabase.xml file is missing? If so, could the appropriate information be manually typed into the AdskHwCertificationDatabase.xml file? While looking through the file, I see several "<!--this next section is hardcoded for the time being.-->" comments.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Certified does not mean it works properly.
"Do or do not... there is no try"
Master Yoda.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The Certified Hardware page does list the Intel HD Graphics 3000 chipset as being supported, which is what is in the MacBook that I'm using.
This is the result of me testing all of the products within Autodesk Product Design Suite 2012 that I normally use:
Graphical Hardware Acceleration Active
- Design Review
- Inventor
- Inventor Fusion
- Showcase
Graphical Hardware Acceleration Inactive
- AutoCAD (to include Mechanical package)
From this, it seems to me that the problem isn't within the hardware or drivers, but the AutoCAD product specifically. I tried modifying the XML file to include information about the GPU, but it had no effect. If I were to speculate on where the problem is rooted at, I'd say it was within AutoCAD's programming that detects GPUs; "hardcoded" graphics card information within the AutoCAD product gives a bit of support to this speculation.
Has anyone had success with another CAD product, such as VectorWorks?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I´ve installed Windows 7 x64 with bootcamp in my MBP 13" i7, this one comes with the INTEL HD 3000 G.card....
when I use Autocad on Win I cant turn on the Hardware accelerator function either, ITS OBVIOUSLY A DRIVER ERROR. couse I can run 3Dmax smoothly.
On the other hand, on mac os I also have autocad for mac and and runs really good. I have read that this situation is global. Autodesk has to fix this soon!!!!
