AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
HELP! Annotation Problem
- Highlight
- Email to a Friend
Hello all, This is likely a really easy fix, but I am struggling with it.
I have an exhibit cabinet that I have layed out for fabrication, and I cannot associate dimensions with the z axis. Autocad will allow me to assocaite dimensions on the x and y axis, but is constrained on the z axis so that I cannot show a vertical dimenstion. The dimension commands will only allow me to show dimensions on the 2-d drawing plane.
The drawing was originally created as 2-d lines and then extruded to the desired height. To determine if it was releated to the specific drawing or not, I exited the program and started a new drawing. I created a 2-d box and a cube, using the "box" command under 3-d basics. I had the same problem with the new drawing, so this suggests to me that I somehow managed to change a global setting on the program itself
I would really appreciate any help you can provide!
Thank you!
Re: HELP! Annotation Problem
- Highlight
- Email to a Friend
You must reorient the UCS, dims only work in XY plane. You can drag the UCS to where you want it or use UCS, 3point, etc.
Also see http://cadtips.cadalyst.com/create-dimension/dimen
- Highlight
- Email to a Friend
Ahhh, I see! That worked perfectly- you're a lifesaver! Thank you so much for your quick response!
