AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Gizmo Problem - Doesn't let me select it
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having a Gizmo problem, and it has been recurring for a long time.
Problem:
When I select an object, either with scale/rotate/move selected, the corresponding Gizmo appears
Great
But as I hover my cursor over it, and it clearly shows I'm over it by changing color, and try to click on it. It disappear.
It's very frustrating as I try to click on it, and it's gone, and the command window displays this message
"Please select an axis" duhhh I can't cuz the Gizmo is GONE. Then I ended not being able to perform all those functions.
Any idea guys?
Dulerong
Re: Gizmo Problem - Doesn't let me select it
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Actually guys,
I found my solution, it's really weird but in case someone with the same problem.
To avoid this:
In 3D mode, Home->Selection then you can see gizmo selection types (scale, rotate, move)
Basically the problem I was having is due to selecting the different gizmo then what I intended to do,
so like this: type "rotate" but had "scale" selected in that tab.
This is not gonna work.
Hope it helps anyone like me.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i've managed to fix this problem with manually typing in 3Dmove, 3Dscale, 3Drotate,
For some reason this problem still persists
I just can't select an object and use the GIZMO right away, like I need to type in the command
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You need to be in a visual style other than 2dwireframe.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi everyone. My problem is that when I change the visual style from the default one (2dwireframe) it seems to crash. I CAN move the mouse... but when I try to change the visual style again from the list above on the left of the window, I CAN'T open the "menu". As well, if I draw a 3d object, then I cannot select it. I can't change the view using teh cube above on the right too. What's my problem. Thanks
