• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    apec_engineering
    Accepted Solution
    Function keys customization
    2209 Views, 4 Replies
    06-02-2011 01:01 PM
    Can anybody help?
    Using the CUI editor I have tried to customize the function keys in Autocad 2012.
    The default for each of the keys is noted here:
    F4
    Command:  <3DOsnap on>
    F6
    Command:  <Dynamic UCS on>
    In Autocad 2006 I have the keys customized to do the following:
    F4
    Macro:  '_zoom_p
    F6
    Macro:  _cen
    Can anybody help?
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Function keys customization
    06-02-2011 01:34 PM in reply to: apec_engineering
    Command CUI, see image (it's from 2010, for 2012 same steps)
    Member
    apec_engineering
    06-02-2011 01:54 PM in reply to: Patchy
    My screen snip from Autocad 2012 cui is attached.
    *Expert Elite*
    Patchy
    06-02-2011 02:07 PM in reply to: apec_engineering
    That comes with Autocad, it's temp. override keys, don't mess with it. When you do as I showed you, drop it at the "SHORTCUT KEYS"  it will work.
    Member
    apec_engineering
    06-02-2011 02:26 PM in reply to: Patchy
    Fine it worked now.
    Drag and drop to the Shortcut Keys section.
    Don't click on the 3 dots button.
    Just type the key combination into the Access Key(s) box (i.e. F6 or F4)
