AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Fitting a polyline contour to a curve
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi there,
I'm in a jam right now and need a solution pretty quick, so I apologise in advance if this is in the wrong section.
I have a sinusoidal curve, that I've created using a third party app, which has worked really well. But the app only produces the form in a straight line and i now need to fit it to a number of curves.
I have a form of 3 radii and a couple of flats, which the sinusoidal form needs to fit along. All this work is just in 2D as i need to output the dxf into a CNC machine.
I hope this makes sense, can anyone help please!?!?!?!
Many, many thanks in advance.
Re: Fitting a polyline contour to a curve
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
start command _PEDIT and look for the options _FIT or _SPLINE (>>>details<<<).
HTH, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the quick reply.
My first problem, is that I'm not sure how either of these commands will work for my situation.
But I have now developed a second problem, in that I can't join the polylines of my form. At the moment I have 6 polylines all end to end in the form that i need, but the Join command won't join these lines.
I figure I need to get the form into a single polyline in order to fit the sonusoidal curve to my form.
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have set a link to the help of _PEDIT in my previous post, there you can read about _PEDIT and how it works.
Joining only works if the endpoints of the segments have the (exact) same coordinates. Any minimal distance would avoid the concatenation of two segments.
So verify (e.g. by command _ID and using objectsnap _ENDPOINT) that the endpoints match together.
If you are willing to allow some tolerance then you can use _PEDIT with the option for selecting multiple objects, that gives you a chance to input a tolerance-value when using option JOIN.
- alfred -
Alfred NESWADBA
