AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Fatal Error: Unhandled e06d7363h Exception at 751d9617h
- Highlight
- Email to a Friend
- Report Inappropriate Content
times to times i have this error in autocad 2011.
i use an: Intel i5 Intel with 8GB memory, running on windows 7 Pro 32bits.
Anyone can help me?
Re: Fatal Error: Unhandled e06d7363h Exception at 751d9617h
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
are you running a certified video card with a certified driver?
You can find the list of certified graphics drivers here:
http://www.autodesk.com/autocad-graphicscard
(have a look at this comprehensive blog post for more information around AutoCAD graphics driver certification:
http://withoutanet.typepad.com/without_a_net/2010/
Regards
Silvia
Silvia Menon
Autodesk Product Support
- Highlight
- Email to a Friend
I´m using ATI Radeon HD5454 1GB DDR3 with the latest driver
- Highlight
- Email to a Friend
Sometimes give error wiles opening files, or jumping between files, or open files with other files opened.
Its an randow error but related with open projects.
- Highlight
- Email to a Friend
you may be running out of memory, since you are running a 32 Bit OS.
To make full use of the system you have (and especially the 8 GB RAM) you may want to consider moving to a 64 Bit OS.
If you need to stay with a 32-Bit OS for some reason, you should consider setting the 3GB switch as described here:
Enabling 3GB switch on Windows Vista™ or Windows 7
http://usa.autodesk.com/getdoc/id=TS1069947
(But please note that even though it is possible to increase the amount of RAM available to applications on a 32-Bit OS in this way, the recommendation is to use a 64-Bit system rather than tweaking a 32-bit system.)
Regards
Silvia
Silvia Menon
- Highlight
- Email to a Friend
hey there i have a similar problem like yours with autocad 2008 i have amd 3.2ghz 4 gb ram ati 4890 1gb ram with latest drivers and 32bit windows ., FATAL ERROR: Unhandled e06d7363h Exception at 755c9617h and its randomly when open drawings , from autocad or Sometimes give error wiles jumping between files, or open files with other files opened and also when i zoom in or regen and then when open another drawing . I try Enabling 3GB switch on Windows Vista™ or Windows 7 but nothing . Also i install clear windows , i update the progam again nothing .
please help...
- Highlight
- Email to a Friend
Hi, I too am facing this error and i'm not too sure how to solve it. I heard that it may be because of running as administrator so that the programme has full access to the o/s. I'm trying this now but any other information would be useful
- Highlight
- Email to a Friend
Hi Nicpapa,
I was able to find your Customer Error Reports in our database. They show that you are running AutoCAD 2008 on Windows 7 which unfortunately is not supported. However, I could also see that an issue related to this particular crash you were experiencing has been addressed in Update 1 for AutoCAD 2010 and in AutoCAD 2011.
To verify this you could download and install the trial version of AutoCAD 2011 from here.
Best Regards
Silvia
Silvia Menon
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi Jope00,
I found a crash report in our Customer Error Report database from a user with an email address very similar to your user name, but it was from AutoCAD 2010, not 2011.
This was linked to an issue that was addressed in Update 1 for AutoCAD 2010.
So if you are actually running 2010 and not 2011, please make sure you install Update 1. (Note: Update 2 includes Update 1 so you may want to just install Update 2)
If you are running AutoCAD 2011, could you please try to once more reproduce the crash, send in the error report to Autodesk and enter your user name in the comments field?
Let me know when done, then I will look up the crash report and see what I can find out.
Best regards
Silvia
Silvia Menon
Autodesk, Inc.
