• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    F1 key now does nothing!
    251 Views, 9 Replies
    01-15-2013 07:18 AM
    Been having ongoing issues with the online help dialogue, autocad's web access mechanism and our proxy server. The short story is that it doesn't work. I'd pretty much accepted the 2 minute delay whilst autocad prods the poxy server then grudgingly serves up the local help pages, only now it doesn't even do that. I'll get a pause/delay whilst something/nothing happens. then nothing actually happens, no exporer window, nothing.
    It's happend on 2 systems I use, XP and window 7.
    It's a long shot, but I don't suppose anyone else has seen this?
    G
    Please use plain text.
    GrantsPirate
    Re: F1 key now does nothing!
    01-15-2013 12:37 PM in reply to: GilesPhillips
    Mine wouldn't work due to security restrictions set by my IT group.  There is a 2012 web page for help, I will look for it unless someone else posts it first.
    http://exchange.autodesk.com/autocad/enu/help
    01-16-2013 12:44 AM in reply to: GrantsPirate
    I've got  a support ticket open with autodesk, and the supplier of our proxy server for the whole web access thing, it's quite painful to be honest as everyone involved is saying their software works fine.
    pendean
    01-16-2013 05:52 AM in reply to: GilesPhillips
    How long does it take you, on one of those PCs, to open this link:
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    01-16-2013 06:04 AM in reply to: pendean
    Not really the point Dean.
    What I'm trying to do is get the software to work as it is intended.
    Would you buy a car, and find that the rear door doesn't open, and think "that's okay" because you can still reach across from the other side?
    pendean
    01-17-2013 06:10 AM in reply to: GilesPhillips
    Since that's all the program is doing, calling a website, you need to find out if it's a browser/internet IT restriction: and as a temporary solution you can map the F1 key to call the web link instead if there is no issue with a direct link.
    But you don't seem to want to try any solution posted here by others, so I'm not sure of the purpose of your post other than a healthy rant. You forget, we all have R2012 and this feature works fine. Oh well, Enjoy your day.
    01-17-2013 06:18 AM in reply to: pendean
    Dean -It's not really a solution, more a work-around.  Show me a solution and I'll try it.
    The overriding issue is one of Autocad not referring to a wpad file for internet configuration- it rather hits the proxy direct and then sulks when it's not let through.  As I mentioned earlier in this thread Autodesk have a support ticket open and are working with our proxy server suppliers for a solution.
    My original post was based on the new development of the help browser window not appearing at all, regardless of weather it is displaying the local help files or the online ones.
    JGerth
    01-18-2013 05:41 AM in reply to: GilesPhillips
    I was going to suggest downloading the Offline help, but it no longer appears on the documentation page under Services and Support.  that..... bites. I didn't think that 2012 was considered officially abandonded:smileymad:
    The PDF documentaiton is available, for what that's worth - but it's not Help.
    Your best bet would be to request the offile help for 2012 from your reseller and install that locally, or download and install the 2013 Help - realizing that it's not going to be right about everything.  Mostly right, but not completely accurate for 2012.
    Product Support
    01-23-2013 07:20 AM in reply to: GilesPhillips
    Do you already have the offline help files installed?
    If you do, in Options > System tab > Autodesk Exchange > uncheck "Access online content (including Help) when available.
    For offline Help browser select "Default System Browser".
    Does it make any difference?
    If it doesn't, select "Internet Explorer (Supports all functionality)".
    Is there any improvement?
    By the way, what is the support ticket number that you have logged with us? I'd like to have a look.
    Cheers,
    Luciane
    Luciane Conceição
    Product Support Specialist
    Product Support
    01-28-2013 09:47 AM in reply to: GilesPhillips
    Did any suggestion work for you?
    Cheers,
    Luciane
