• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    kevin
    Error message when plotting from Sheet Set Manager
    149 Views, 2 Replies
    05-24-2012 04:12 PM
    When I try to plot using Page setup override in the sheet set manager I keep getting the message: Data Link Files with an option for yse or no. Then my Plot automatically turns into an etransmit.  I sure I'm missing something simple. Please help me out.
    Please use plain text.
    kevin
    Re: Error message when plotting from Sheet Set Manager
    05-31-2012 12:09 PM in reply to: kevin
    Ok so I figured out the etransmit  issue but the warning stll pops up.  once I hit no it continues to plot. More annoying than anything else. Any ideas any one.?
    Active Contributor
    11-15-2012 05:13 AM in reply to: kevin
    I just went threw this issue.
    It ended up being the drawing and sheet set not matching. I had removed a tab in the drawing after I imported it into the ssm and did not remove it in the ssm. After removing the sheet in the ssm the issue was resolved.
