• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    M_Mogharabi
    Error : Exception has been thrown by the target of an invocation
    441 Views, 1 Replies
    01-09-2012 12:51 AM
    I have written an external application to drive autocad with a dll that was registered for COM. I have followed this codes to write my application however i have replaced the following code with AddNumbers() method:
    public string OpenDWGFile(string MyDWGFilePath)
    DocumentCollection dm = Application.DocumentManager; Document doc = null; if(File.Exists(MyDWGFilePath)) { doc = dm.Open(MyDWGFilePath, false); Application.DocumentManager.MdiActiveDocument = doc;
    return "This file is exists";
    else
    return "This file is not exist";
     but when i run my application the autocad software open and then close immediatly and this error message is shown : Exception has been thrown by the target of an invocation.
    but if i comment the following lines of my code the application works without any errors:
    please help me.
    Please use plain text.
    Active Contributor
    M_Mogharabi
    Re: Error : Exception has been thrown by the target of an invocation
    01-11-2012 01:51 AM in reply to: M_Mogharabi
    Hi everyone,
    I have solved my problem by using this updated code instead of previouse code.
