• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    iwcwoodworker
    Enterpsie CUI & Workspaces
    244 Views, 3 Replies
    12-28-2011 05:46 AM
    Trying to finalize an enterprise CUI that contains some comapny specific workspaces. Can't keep the workspace from trying to auto-creat a quick access toolbar though. The enterprise CUI is read-only so the QAT fails to load when the system tries to create it. I've deleted teh QAT out of the Enterprise file AND the saved workspace, but it still keeps creeping back in.
    Any thoughts?
    Please use plain text.
    Product Support
    Volker_C
    Re: Enterpsie CUI & Workspaces
    12-30-2011 11:00 AM in reply to: iwcwoodworker
    Are you attempting to modify the Enterprise CUIX while it is loaded? As you pointed out the Enterprise CUIX is read-only and when you restart AutoCAD the menu will revert its settings when reloaded. You will need to modify the Enterprise CUIX as a partial or main menu in order to edit the QAT, then reload it as the Enterprise CUIX.
    I hope this helps, if not would you please clarify the issue?
    Volker
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Please let us know if your questions have been answered by selecting, "Accept as Solution"
    Volker Cocco
    Support Specialist
    Product Support
    Product Support
    Volker_C
    01-04-2012 03:39 PM in reply to: iwcwoodworker
    I wanted to follow-up and see if you resolved this issue or if you can provide the additional information I had requested.
    Volker
    Volker Cocco
    Support Specialist
    Product Support
    Valued Contributor
    iwcwoodworker
    02-25-2012 05:36 AM in reply to: Volker_C
    Thanks for posting, but no i didn't resolve the issue. I attempted several different process concepts, utilizing different files for both the main and enterprise CUI's to see which way would be the best to deliver tools and workspaces to a large workgroup. In then end I havn't been able to accomplish what I set out to do:
    My concept was this:
    1. Utilize the Enterprises CUI to deliver our custom tools, modified standard ACAD tolls, modified contextual tool states AND company standard customized workspaces.
    2. Concolidate the ACAD Mechanical and core ACAD cui files in order to take advantage of tools from both
    2. Utilize the Main CUI to allow users to save their personal workspaces and to deliver the core ACAD tools.
    What I found:
    1. Workspaces in the Enterprise CUI won't work due to the quick-access toolbars. When loading a workspace from the Enterpise CUI I would contantly get a warning that it was "read only" and couldn't create the quick access toolbar (this is when ACAD is loading the interface, this is not me working through the CUI editor trying to update a read-only file). This would happen even after I would deisgn the toolbar within the CUI implicitly and assign it to the workspace.
    a. Most frustratingly, the quick access toolbar would somtimes appear within workspaces that they weren't associated with. I would then get the same error because ACAD was attemtping to write some CUI information to my read-only Enterprise file.
    2. I couldn't use the Enterprise CUI to deliver core ACAD tools (in modified form) without having to recreate any associate icons. Even when "importing" from another CUI, the core commands are frustratingly locked out from us to be able to modify and therefor deliver in ways specific to our organization. Unless the ACAD cui and associated DLL files are coordinated properly I would end up with the "?" icon. I had wanted to deliver, company wide, modifications to ribbon states and other contextual tool states from a central file. However this became troublesome enough that I've abandoned the idea.
    These were just a coupld of the issues I encountered. In the end I wasn't able to accomplish what I thought would be an efficient way to manage company standards from a single location.
    I'm no CUI expert, but not a newby either. I worked through quite a few work-flow possibilites and ran into quirky results at most turns. At this point i'm of the impression that Autodesk doesn't have it's work-flow thoughts quite squared away on the use of these files.
