• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    Embedded OLE DWG objects in word 2010 not opening with AutoCAD 2012
    181 Views, 2 Replies
    02-12-2013 11:54 AM
    Trouble with embedded OLE DWG objects in word 2010 not opening with AutoCAD 2012
    We have a user that can't open some OLE DWG files from within a word document. He had 2010 AutoCAD LT on his machine for a while then was upgraded to 2012 AutoCAD (non LT) once that was there LT 2010 was unistalled. since then he has not been able to open certain embedded OLE files within Word. Other users that have other ever had AutoCAD 2012 have no issue opening this embedded DWG files.
    i found this thread (http://forums.autodesk.com/t5/AutoCAD-2013/Editing-Excel-2007-Embedded-Autocad-Drawing-Problem/td-p/...) which sounds exactly what is going on with my enduser. But the fix provided is for AutoCad 2000-2012 not the LT versions.
    Can anyone help as he is really struggling with this issue.
    Please use plain text.
    JGerth
    Re: Embedded OLE DWG objects in word 2010 not opening with AutoCAD 2012
    02-12-2013 12:58 PM in reply to: ScottPare
    from the looks of that link, there's no reason his fix would not apply to LT as well as full
    New Member
    02-12-2013 01:10 PM in reply to: JGerth
    No I expected it not too but it was worth a shot. Need to know what the reg key is the pointer for LT
