AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Elevation (Z) out zero
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a problem with lines that begin and end outside the Z is zero, and polylines with elevation outside the Z zero. The difference is very small, for example, -0.00000112, or 0.00000078. I checked the possibility of using the Flatten command but does not always work, even though there hatches in the drawing. Polylines and Blocks also cause problems with the command by flatten. This has become a disease in autocad. (attached)
Help us!
Re: Elevation (Z) out zero
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Stop the disease by starting your drawing with the right setting of OSNAPZ
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Patchy wrote:Stop the disease by starting your drawing with the right setting of OSNAPZ
Ok! This tool is known to us, and is active on computers that has AutoCAD 2010 standard or mechanical version, but we have machines that holds AutoCAD LT, LIGHT version, this version have limited resources e does not have this osnap setting.
Often, for the beginning of a work detail, is generated copies of drawings used as reference, these references are the disease. The solution consist in cure fast these primary drawings , so that we do not need new lines. This also would solve the problems of the AutoCAD LT version
Thanks for your reply!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Place this MACRO on a BUTTON.
^C^C_UCS;;_move _all;;0,0,1e99;;_move _all;;0,0,-1e99;;_chprop;_all;;_thickness;0;;^M;
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
SugarCAD wrote:Place this MACRO on a BUTTON.
^C^C_UCS;;_move _all;;0,0,1e99;;_move _all;;0,0,-1e99;;_chprop;_all;;_thickness;0;;^M;Nice work SugarCAD! Very Thanks!
Only one problem for solve, blocks within blocks. The command sends all to Z zero, but the lines that are inside the blocks remain outside Z zero. We must apply the Macro in Block Editor or Reference Edit to change the lines, polylines, etc. In some drawings, we have a wide range of blocks within blocks. Is possible to add a solver blocks within blocks in the macro that you created?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Conclusion until then: The machines with Autocad Standard Version are configured with OSNAPZ = 1 as according to the contribuition of the "Patchy" and the post: <http://forums.autodesk.com/t5/AutoCAD-2010/Save-OS
But in autocad LT this is not possible.
In LT is possible to create a button with the macro who "SugarCAD" gave us up here, worked in Sandard version and LT version , unlike in the said "pendean."
the problem of elevation out of ZERO has not been completely resolved, but it was much mitigated with contributions.
Thanks again for all contribuition!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For complete: if after all you not move your object to elevation zero, try enter manualy on PROPERTIES of the objects that you need change Z, pick "0E99" rather than only "0". This input represent the zero absolute, and solve the problems like a texts or blocks with texts aparently in bold, independent, that before had not been changed for bold by you.
Regards.
