• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Member
    Accepted Solution
    Edit Xref In-Place
    632 Views, 3 Replies
    02-27-2012 08:35 AM
    I hope some one can help with this problem.
    When saving an AutoCAD drawing there is a Thumbnail image saved (if you have the option turn on), but when the command "Edit Xref In-Place" is used there is no Thumbnail image saved. So now when I try to preview any drawing that has been edited through this command there is no longer a thumbnail.
    I am using AutoCAD 2012 and the option to save a thumbnail is turned ON.
    Thanks in advance for any help you might have.
    Jeromey
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Edit Xref In-Place
    02-28-2012 04:58 AM in reply to: jeromey
    It behaves as you note.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    02-28-2012 07:35 AM in reply to: pendean
    I am confused by your answer.
    Maybe my question was not so clear.
    I am wondering if there is a way that "edit xref in-place" will create a thumbnail?
    As of right now there is only a thumbnail created when I save a individual drawing but no thumbnail created using "edit xref in-place".
    *Expert Elite*
    JGerth
    02-28-2012 09:20 AM in reply to: jeromey
    short answer, Edit XREF in place does not save a thumbnail.  if that's important, use XOpen instead of RefEdit.
    sorry buddy, that's just the way it works
