• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    Dynamic title blocks
    186 Views, 5 Replies
    02-04-2013 12:09 PM
    I need to create a dynamic title block, so I can change the date on layout 1 and all the others change too. Can someone point me in the right direction to learn how to do this?
    AutoCAD Civil 3D 2012 SP2
    Windows 7 (64)
    Please use plain text.
    Valued Mentor
    Re: Dynamic title blocks
    02-04-2013 01:09 PM in reply to: jamesbarnett
    Add your date to the Custom tab of Drawing Properties(dwgprops). Put a field in the title block to retrieve this value.
    Active Contributor
    02-05-2013 05:08 AM in reply to: tim.turner
    How do I retrieve the value?
    Windows 7 (64)
    Valued Mentor
    02-05-2013 05:19 AM in reply to: jamesbarnett
    In the title block insert a field, in the Field dialog set the Field Category on Document and you should see your custom properties.
    When you have your drawing template file the way you want you can use the command Propulate to export a custom properties template and import it into an existing drawing. Propulate is not the most straightforward command so have some patience and pay attention to the command line.
    Distinguished Contributor
    02-05-2013 05:20 AM in reply to: jamesbarnett
    I would use a sheet set.
    Active Contributor
    02-05-2013 05:24 AM in reply to: tim.turner
    Thanks for the help.
    Windows 7 (64)
