• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Dynamic Block Problem
    350 Views, 4 Replies
    08-02-2011 12:47 PM
    Please, help.
    I've got Dynamic Block called 'Flange'. When I'm trying to change it to another dimension,
    from original 6", I got this block the wrong way - please see attachments.
    Same block, though works in other drawings.
    Thanks in advance.
    Please use plain text.
    Product Support
    Re: Dynamic Block Problem
    08-04-2011 06:58 AM in reply to: valeryschorstein1478
    Please send the block so that we can have a look.
    Cheers,
    Luciane
    Luciane Conceicao
    Product Support Specialist
    08-04-2011 07:26 AM in reply to: valeryschorstein1478
    Thanks for your help. Here's this block.
    Please don't forget, that when I insert this block from
    tool pallet in other drawings it's working.
    *Pro
    nestly
    08-04-2011 10:46 AM in reply to: valeryschorstein1478
    The block is only partially contrained. Open the block editor, click "autoconstrain" and select everything.  Seems to work fine after saving the block.  The only thing I'd change is that I'd make the basepoint remain at the center of the neck regarless of size.
    I don't see any reason why it would work better or worse when inserted from a tool palette?
    08-10-2011 06:21 AM in reply to: valeryschorstein1478
    I was out of office on field trip and didn't have a chance to check it.
    Now I tried and it's working. Thank you very much.
