• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    Dynamic Block Array
    1046 Views, 3 Replies
    11-15-2011 05:53 AM
    Is there a way of making a dynamic block array whereby one can put in a parameter and stretch action to adjust an array parameter specifically centres so that effectively the dynamic block could replicate the AutoCAD 2012 command line array?
    Please use plain text.
    *Expert Elite*
    Re: Dynamic Block Array
    11-15-2011 08:39 AM in reply to: paulstubbs
    Dyn blocks have array actions so depending on your scenario yes it can.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    New Member
    11-15-2011 08:43 AM in reply to: mathewk
    Have tried, and can make an array with a frequency setting, but how do you make that frequency adjustable from another action / parameter?
    Product Support
    pagerodney
    12-05-2011 03:02 PM in reply to: paulstubbs
    You could create a look up table associated with your Parameter Properties.
    You may also find extra help in the Dynamic Blocks discussion area:
    http://forums.autodesk.com/t5/Dynamic-Blocks/bd-p/154
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Rodney Page
    Support Specialist
    Product Support
    Autodesk, Inc.
