• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    Duplicate Attribute (echo)
    188 Views, 2 Replies
    11-16-2012 02:25 AM
    I have a drawing template (block) where the drawing number is displayed in two locations (attributes). The same value has to be entered in both attributes.
    Is there any way of "echoing" the data from one attribute to other attributes (or text objects)?
    Please use plain text.
    Re: Duplicate Attribute (echo)
    11-16-2012 05:21 AM in reply to: thebeesnees
    using fields can do that (>>>details<<<).
    Check the attached drawing with one sample block inserted. Change it's attribute "ORIG" and after that do a _REGEN.
    - alfred -
    Alfred NESWADBA
    Active Contributor
    11-16-2012 06:08 AM in reply to: alfred.neswadba
    Almost perfect.
    Only minor issue is that the second attribute (COPY) can be overwritten accidentally. Would be ideal if the second attribute could be hidden or protected although I don't think it is possible.
    Does the job though, thanks for your help.
