• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    dipen
    Draw Order
    205 Views, 4 Replies
    09-26-2012 11:15 PM
    When I first started using 2012 LT, when you clicked on a line on top of another line a box appeared and you could select from a list which line or object you were trying to select. The box no longer appears. How do I activate it?
    Also is it possible for me to go back to the selection tool in older versions where you could use the space bar + shift torun through the different lines on screen and then select the right one?
    Ay help would be appreciated. Thank you.
    Please use plain text.
    pendean
    Re: Draw Order
    09-27-2012 05:35 AM in reply to: dipen
    Turn on Selection Cycling (Icon on the  bottom of the autocad screen, green square in front of a white scquare with a + behind that.
    Use the arrow keys (up or down) to scroll through the command line history? Have DYN turned on.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    Re: Draw Order
    09-27-2012 08:01 AM in reply to: dipen
    shift space bar still works.
    dipen
    Re: Draw Order
    09-27-2012 10:00 PM in reply to: 03xtreme
    Perhaps they removed it from LT, not on mine it doesn't.
    Valued Contributor
    Re: Draw Order
    09-28-2012 11:24 AM in reply to: dipen
    sorry, I missed the LT part.... that sucks then!
