• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    TexShalter
    Double click CUI menu
    78 Views, 1 Replies
    02-04-2013 02:40 PM
    Trying to change the Hatch doubleclick command from quickproperties  to the familiar hatch edit dialog.
    When I go to the cui, hatch edit doesn't even appear as a command. There a lots of commands that don't appear in the CUI command list.
    I added it, but I cannot get it to stick when I drag it to HATCH in the doubleclick list
    The the HATCH Advanced element box "ID_QUICKPROPERTIES" is greyed out so I cant retype it to "hatchedit"
    It could be because I let autocad migrate from 2008 (pre ribbon) when I installed.
    I'm stumped ...
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Double click CUI menu
    02-05-2013 05:31 AM in reply to: TexShalter
    No AutoCAD menu ever contained "every command". Still doesn't.
    but HATCH EDIT, the name used in the Commands List for HATCHEDIT command, is there in R2012's CUI. Simply drag and drop it from the Commands List to the hatch listing under Double-Click Actions. It works great here.
    After you APPLY and OK out of the CUI pop-up, use WSSAVE command to save your current workspace.
    IMHO, it was unwise to let AutoCAD auto-migrate from R2008 for you.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
