• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    *Nathan
    Does 2011 read colorbooks?
    534 Views, 8 Replies
    05-30-2010 03:07 AM
    2011 doesn't seem to read colorbooks correctly.
    The search path is there. It loads the CB ok.
    Is there some conversion necessary for v2010 products?
    Please use plain text.
    *Dean Saadallah
    Re: Does 2011 read colorbooks?
    05-30-2010 07:21 AM in reply to: *Nathan
    Where did you place the files?
    Is that where Options>Files tab setting is looking for them? Post a
    screenshot of that tab expanded.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    *Nathan
    05-30-2010 07:56 AM in reply to: *Nathan
    Here's a shot showing it loaded and compared with ACA09 colours.
    Also fine in ACA2010.
    Benjamin Moore look ok
    Some Pantone look ok. Others weird. No perhaps they're ok. Same as 10
    anyway.
    Resene all bad
    Sherwin all bad.
    Something fixed. Something broken. Sigh!
    "Dean Saadallah" wrote in message
    news:6400080@discussion.autodesk.com...
    Dean Saadallah
    *Dean Saadallah
    05-30-2010 09:01 AM in reply to: *Nathan
    The vertical slider?
    I have the free Pantone, SW and BM loaded, they look the same as always
    here. BM AC looks like yours, but no "colorbond" here per your post where
    you seem to be having issues. Maybe that's where the problem is?
    Dean Saadallah
    *Nathan
    05-30-2010 04:07 PM in reply to: *Nathan
    cb is one I have made myself and used since about ADt2004 without problems.
    as you can see the same file works fine in 2010..
    news:6400086@discussion.autodesk.com...
    Dean Saadallah
    Valued Mentor
    05-31-2010 03:36 PM in reply to: *Nathan
    Sounds like a graphics card issue to me Nathan. Are you using the same 3dconfig setting in 2011 as in 2010? Have you updated the xml database?
    *Nathan
    05-31-2010 04:25 PM in reply to: *Nathan
    no I haven't. I'll take a look at that.
    wrote in message news:6400408@discussion.autodesk.com...
    Active Contributor
    05-31-2010 11:09 PM in reply to: *Nathan
    I have been having the same problem with my old colorbooks. While searching I found a thread in the civil 3d forum where people are having the same issue. http://discussion.autodesk.com/forums/thread.jspa?messageID=6391275藫
    I've reposted my pic here if anyone wants a look. It seems to me autocad is just plain screwing up the values rather than it being a graphical issue. What did you mean RE: 'updating the xml database' ?
    *Nathan
    06-01-2010 06:35 AM in reply to: *Nathan
    Would appear they have updated the colour book definition.
    Be great if they have a tool to update existing ones.
    Might be because of the changes to the materials and rendering engine.
    Hi Elmato, where did you get the colorbond list from. Yours looks
    official.
    Mine I made up.
    wrote in message news:6400488@discussion.autodesk.com...
    issue.
