• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    Accepted Solution
    Distance rubber band line is black?
    800 Views, 5 Replies
    05-24-2011 11:07 AM
    One drawing we have has a weird quirk. The rubber band line for the Distance command is black. The background of our AutoCAD is also black, which makes it very hard to see. This only seems to affect the Distance command as the rubber band for the Line command is grey (though the current layer is yellow).
    I have confirmed this is limited to just one drawing, no matter what machine you open it on. The AutoCAD version we are using is Civil 3D 2011.
    I have checked the following: DRAGMODE (auto), HIGHLIGHT (1), restored colors to default, made sure 3D views were not on, rendering off, UCS set to world.
    Next step? Repairing the AutoCAD installation is not likely to fix the problem.
    Thanks!
    Please use plain text.
    Re: Distance rubber band line is black?
    05-24-2011 12:15 PM in reply to: cvc-it-mb
    Change the color of layer 0 (zero) back to white.
    Active Contributor
    05-24-2011 01:26 PM in reply to: Johneng
    Thanks for the heads up.....
    That wasn't exactly the problem though. Layer 0 was white, but it was frozen. Unfreezing it fixed it.
    Why oh why is Layer 0 tied to so many arbitrary things!
    PeteMiller
    08-03-2012 10:59 AM in reply to: cvc-it-mb
    Question, I'm running Autocad Mechanical 2011, the Distance "rubber-band" line doesn't show up at all, I've tried all the suggested fixes here to no avail. Is there a setting for changing the color of the rubber band? I'm running with a 'gray' (i.e. #253 color back ground) nothing I've tried affects it. Any help would be appreceated.
    Active Contributor
    08-03-2012 11:54 AM in reply to: PeteMiller
    Does it only affect 1 drawing?
    Layer 0 is color white, and not frozen in Model space or Viewport?
    PeteMiller
    08-03-2012 12:36 PM in reply to: cvc-it-mb
    No, its in all drawings, layer 0 is not frozen and the color is white.
