• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    felt33
    Disappearing Cross Hairs when I try to use crossing fence
    289 Views, 3 Replies
    06-04-2011 08:38 PM
    Hi All,
    Ok this is a new one (for me anyway).
    First, I am using AutoCAD 2010 Full on a 64 bit system with windows 7
    Now, the problem is that when I try use a crossing fence (upper right to lower left or visa-versa), my cross hairs and aperature disappear and the fence does not show up. Everything is set right in options and it was working before (untill now). I tried restarting my computer, checking the options, pickdrag set to 0. I can't think of anything else. Audit brings back no errors as well as recover.
    Any Ideas?
    Kyle
    Please use plain text.
    *Pro
    nestly
    Re: Disappearing Cross Hairs when I try to use crossing fence
    06-05-2011 04:27 AM in reply to: felt33
    Technically, the crosshairs are supposed to disappear when you're in selection mode, but they're supposed to be replaced by a pickbox/selection window.  However IF the crosshairs are the same color as the background AND SELECTIONAREA is set to 1  (colored selection window) AND hardware acceleration is enabled, the Pickbox and Selection window will be invisible.
    Solutions:
    Set the crosshairs to a different color than the background
    OR
    Disable the colored Selection Window (set SELECTIONAREA to 0)
    OR
    Disable hardware acceleration.
    Obviously, changing the crosshair colors is the best solution since AutoCAD automatically inverts the display color of the crosshairs anyway if the crosshairs are the same color as the background.
    felt33
    06-05-2011 12:01 PM in reply to: nestly
    Thanks Nestly. I can't believe I never thought to check that. How does that change all by itself? I had all of my options saved in a profile, but the profile somehow changed.
    *Pro
    nestly
    06-05-2011 12:49 PM in reply to: felt33
    Well, I only know the combination of settings that cause the selection window to go invisible, I don't have an explaination of how they got that way....  :smileywink:
