• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Disable plugins
    1023 Views, 7 Replies
    05-02-2011 03:22 AM
    Is there a way to disable plugins?
    For instance I don't currently use Alias, but I still have to load the plugin on autocad start up.
    AutoCAD 2012.
    James
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Disable plugins
    05-02-2011 05:58 AM in reply to: jameswillo
    Rerun the installer and remove it would be the ideal fix.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    Re: Disable plugins
    05-02-2011 06:02 AM in reply to: pendean
    I would rather disable than uninstall in case I need it in the future. I hate running installers.
    Thanks for the idea though anyway.
    Distinguished Contributor
    Re: Disable plugins
    05-02-2011 06:07 AM in reply to: jameswillo
    Here is the help topic regarding plug-ins:
    file:///C:/Program%20Files/Autodesk/AutoCAD%202012%20-%20English/Help/filesACR/WS73099cc142f487555f687a1012bf24b54f2-7c96.htm#WS73099cc142f487555f687a1012bf24b54f2-7c95
    Just type in APPAUTOLOAD at  the command line and change the value to zero. Then close AutoCAD and restart it and the plug-ins will not load
    I set mine to 0 and no plug-ins load and I think it runs a little smoother. If you want to verify that nothing is running, type APPAUTOLOADER at the command line and then hit enter for "list" and it should say that no application bundles are loaded.
    Valued Contributor
    Re: Disable plugins
    05-02-2011 06:14 AM in reply to: jameswillo
    So it's all or nothing?
    In Inventor you can specify which plugins load and which don't.
    *Expert Elite*
    pendean
    Re: Disable plugins
    05-02-2011 06:19 AM in reply to: jameswillo
    This is not Inventor... .
    Valued Contributor
    Re: Disable plugins
    05-02-2011 06:29 AM in reply to: pendean
    Yep, shame they can't make things as user friendly as they do on Inventor.
    Re: Disable plugins
    06-12-2011 07:30 PM in reply to: jameswillo
    I must say unloading the plugins mage a dramatic reductionin time to load ACAD!
    R
