• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    jaultman
    Dimensioning multiple viewports in layout
    515 Views, 4 Replies
    01-19-2011 09:33 AM
    I was never formally trained on 3D AutoCAD. I imagine this will be a simple question.
    I would like to do all dimensioning in paperspace despite the standard practices of all the other engineers in my company. I have modeled a relatively simple 3D object and created a layout in which I have 2 viewports; one for the front and one for the right view. How do I dimension the object in each viewport without causing the dimensions from "viewport A" show up in both viewports?
    By double-clicking a viewport, it seems I am then working the Model space, even though I'm still on the Layout tab, because anything I draw, type, etc. in that viewport will show up in the other. So when I double-click outside both viewports, i.e. to work on the layout itself, I cannot snap on to the object in either viewport for dimensioning.
    What am I missing? Thank you in advance.
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Dimensioning multiple viewports in layout
    01-19-2011 09:36 AM in reply to: jaultman
    make 2 layers for dimensioning, shut off 1 in other viewport.
    Active Member
    jaultman
    01-19-2011 09:57 AM in reply to: Patchy
    That brings me to my next question: how do you turn off a layer in one viewport without affect the layers shown in the other? When I am in "viewport A" and I shut off a layer, that layer also becomes invisible in "viewport B".
    Somehow I can dimension in paperspace now without having to enter the individual viewports. OSnap isn't working quite as I'd like, though. But I think that is due to the geometry of my object and the way in which it was modeled.
    Thanks for your quick reply!
    *Expert Elite*
    Patchy
    01-19-2011 10:01 AM in reply to: jaultman
    It only works when it is "Though" the viewport while in paper space, use the icon that looks like the sun with a spare, click on it.
    Active Member
    jaultman
    01-19-2011 10:22 AM in reply to: Patchy
    yup, I should have known that. Thank you!
