• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    bojko108
    Accepted Solution
    Dimension styles
    227 Views, 2 Replies
    08-09-2011 10:29 PM
    Hello!
    I have a question about dimension styles. The attachment showing two lines (in red) and they are dimensioned with different dimension styles. The left dimension style is by default and the right is modified. I suppressed the dimension lines but there is one symbol (a dot) in the right one.
    Is there a way to hide this dot?
    Thank you!
    Please use plain text.
    *Expert Elite*
    Re: Dimension styles
    08-10-2011 12:39 AM in reply to: bojko108
    The dot is part of the dimension and is placed on the layer defpoints.  If you don't want to see them on the screen, you either turn the layer off or freeze it.  You don't have to worry about it if you leave the layer on because the layer defpoints is automaticly a no plot layer.
    Valued Contributor
    bojko108
    08-10-2011 04:00 AM in reply to: azrdgldr
    Thank you :smileyhappy:
