• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Dimension Input Prompt
    740 Views, 8 Replies
    08-15-2011 11:23 AM
    What or where is the setting to change the dimension value input to automatic rather than accepting the default everytime I put a dimension in?  I don't want to be prompted for input.
    Bo
    Please use plain text.
    Valued Contributor
    Re: Dimension Input Prompt
    08-15-2011 11:04 PM in reply to: bobarket
    Dimension Style Manager -> Modify -> Primary Units -> Measurement scale -> Scale factor: ... (write factor)
    08-16-2011 08:44 AM in reply to: nikolap
    Appreciate the response but I'm not sure this was the solution.  Anyway, I tried it and nothing changed.  After I select a location for my dimension I'm asked to accept the default value or type in my own value.  I don't want this prompt.  I only want to place the dimension after I select a location without being prompted.  Sorry if I'm not getting it.
    Bo
    New Member
    ronaldalau
    11-14-2011 01:46 PM in reply to: bobarket
    Just found it:
    Autocad Mechanical 2012
    Options, AM:smileyfrustrated:tandards tab
    right click 'Dimension' click settings to get to 'Dimension Settings' dialog.
    Down at bottom, "Display dimention text editor:"  Choose 'Only on Demand' in dropdown list.
    Hope this helps.
    Picture is related.
    11-14-2011 02:07 PM in reply to: ronaldalau
    sorry but i don't have AM standards tab.  is there a command line entry to get to the dimensions settings dialog
    11-14-2011 04:28 PM in reply to: bobarket
    You have to hit "ENTER" to accept the default value and complete the command.
    I don't think there is any other way around that. nikolap's reply is worth taking a second look.
    AutoCAD Map 3D 2013
    Windows Vista Business
    Service Pack 2
    Intel(R) Core(tm2) Quad 3.0 GHz
    4.0 GB RAM
    Distinguished Contributor
    JIMDONALDSON6595
    11-15-2011 07:20 AM in reply to: bobarket
    On my 2012 dimensions, It does not prompt for a location. But I cannot figure out which variable is controlling this. I am attaching a DWG with my settings and examples
    Jim
    JIMDONALDSON6595
    11-15-2011 07:31 AM in reply to: JIMDONALDSON6595
    Sorry I meant it does not prompt for text after location.
    Jim
    New Member
    10-11-2012 09:37 AM in reply to: bobarket
    Type in Command Line: [dimassoc ] set value to [2]
