• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    Detemining whether install is x32 or x64
    116 Views, 1 Replies
    07-30-2012 01:54 PM
    How does one determine if the version of AutoCAD that is installed ( 2012 mechanical in this case ) is an x32 or x64 bit installation.  Normally I would just look to see if it was installed under Program Files or Program Files ( x86 ) but it is located on D:\ drive under another folder so I don't have that option.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Detemining whether install is x32 or x64
    07-31-2012 05:36 AM in reply to: mario.casol
    It matches your Windows bit version: the installer will not mix and match on it's own, ever.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
