• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Stemdriller
    Accepted Solution
    Designed By Attribute
    237 Views, 9 Replies
    04-19-2012 05:30 AM
    Hi All
    As in my previous posts I am very new to this AutoCAD lark.
    All I am trying to do at the moment is create an attribute on a drawing template that will simply display the users username.
    I am hoping then that this will be presented as 'Designed By' or something similar, on the drawing and then I am hoping to try and get it into Vault.
    Hope someone can enlighten me.
    Gareth
    Please use plain text.
    Member
    Re: Designed By Attribute
    04-19-2012 09:24 AM in reply to: Stemdriller
    To make the attribute type
    ATTDEF
    When the dialog box appears
    Select - Preset.  This will allow you to edit the block that contains the attribute.
    If you enter the values shown for TAG, PROMPT & DEFAULT like this:
    Attribute Define DLL
    When you edit the block that contains the attribute with the ATTEDIT command, it will look like this:
    Attribute Edit
    Valued Contributor
    Stemdriller
    04-20-2012 12:11 AM in reply to: Stemdriller
    Thanks for the reply.
    But can I get the 'Designed By' to default so that it automatically takes the users username.
    So in my case  if I begin a dwg, it will automatically populate the 'Designed by'  with jgw2, my Windows username?
    Gareth
    Distinguished Mentor
    Moshe-A
    04-20-2012 03:49 AM in reply to: Stemdriller
    Gareth,
    well one way to do it is to define the DESIGNER-NAME attribute value as field
    first you need to add this expression to your acad.lsp (or any other lisp file that is autoload)
    (setq username (getenv "username"))
    now prepare your title block and invoke the ATTDEF command
    in tag field enter DESIGNER-NAME
    in prompt field enter Design Name
    in Default field click on the Insert Field button...this opens the Field dialog box
    then select "Other" Category
    Field name -> LispVariable
    and roll the list to find the username
    (it should be there if you add the expression to acad.lsp and load it)
    finish with ATTDEF dialog and define your block
    after inserting your title block save the dwg and reopen it you will see that
    the user name is update
    another way of doing it is with autolisp but that's totally another story
    GoodLuck
    Moshe
    *Pro
    M_Hensley
    04-20-2012 03:57 AM in reply to: Stemdriller
    You could use a field instead.
    When in the text command right-click and select insert field.
    In the field names list select DeselExpression.
    In the diesel expression area type $(getenv, username)
    Moshe-A
    04-20-2012 08:30 AM in reply to: M_Hensley
    Yes Hensley, you are absolutely right, this saves the use of acad.lsp
    thank you very much for your remark
    Moshe
    Valued Contributor
    Stemdriller
    04-22-2012 11:47 PM in reply to: M_Hensley
    Fantastic, thanks for this.
    That has opened a few doors for me.
    Gareth
    Valued Contributor
    Stemdriller
    04-22-2012 11:48 PM in reply to: Moshe-A
    Thanks for responding.
    I am just starting to look at .lsp files, didn't realise you could use them for things like this.
    Gareth
    Valued Contributor
    Stemdriller
    04-23-2012 02:47 AM in reply to: M_Hensley
    Hensley
    I foolishly thought that when the username command took the current users username, that when another user opened the drawing it would keep the existing username. But it doesn't it overwrites with the other user (If that makes sense!)
    What I am trying to achieve is that the creator of the drawing will always appear on the DWG file??
    Can you help?
    Gareth
    *Pro
    M_Hensley
    04-23-2012 04:07 AM in reply to: Stemdriller
    I don't know how to display who created the drawing. You can display who saved it last, if that helps. Or if you fill out the author field of the drawing properties (using DWGPROPS command) you can display that.
    To display who saved a drawing last, instead of selecting DieselExpression select LastSavedBy.
