• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Design Center window doesn't re-hide
    121 Views, 2 Replies
    02-22-2010 12:41 PM
    I have my Design Center tool pallete anchored to the right of my screen. After I insert a block, the window doesn't auto-hide - I have to drag the window off and re-anchor it every time. I tried anchoring it on the left side, same results.
    This only happens with Design Center, I have other windows anchored on both sides and they behave just fine. Any ideas?
    Please use plain text.
    *Dean Saadallah
    Re: Design Center window doesn't re-hide
    02-22-2010 02:42 PM in reply to: abulla
    You did not mention it so I will ask: is auto-hide turned on for that
    palette? If it is, did you try toggling it on and off to test?
    Does it auto-hide if turned on and not docked?
    Dean Saadallah
    http://LTisACAD.blogspot.com
    02-22-2010 03:02 PM in reply to: abulla
    Yeah Auto-hide is checked and it still happens when I undock the Design Center.
