AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Default Support File Search Paths
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi All,
This may seem like a silly question, but when you start autocad for the first time, it creates a profile with the default support file search paths. Where does AutoCAD get this from?
I want to use this for a tool I am creating.
Re: Default Support File Search Paths
- Highlight
- Email to a Friend
Brent,
Command: setvar acadprefix
will give you the support file search path (it was written to registry when you install AutoCAD)
clearify what do you mean by tool?
Moshe
- Highlight
- Email to a Friend
Thanks!
- Highlight
- Email to a Friend
Thats the one I am looking for. Do you know how to access the initial value of that?
- Highlight
- Email to a Friend
ACADPREFIX contains the initial value plus the paths the user add since the install
- Highlight
- Email to a Friend
Is the initial value stored anywhere (ie in the registry)?
- Highlight
- Email to a Friend
The only reason I ask is that I need to be able to access it programatically
- Highlight
- Email to a Friend
I believe the initial paths are partially hard-coded, using some of the installation information as the starting point for the drive and first few folders. You might be able to pull some of this information out of the registry, but it would be just as easy to hard-code it yourself in the registry or a data file rather than re-calculate it every time.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
- Highlight
- Email to a Friend
here it is:-
HKCU\Software\Autodesk\AutoCAD\R1XX.X\ACAD-XXXX:XXX\Profiles\Your Default Profile\General\ACAD
where XXXX it is version dependet
in key "Profiles" you should read the (Default) key and have Your Default Profile
and key ACAD contains what you are after.
Moshe
