• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    BrentBurgess1980
    Default Support File Search Paths
    200 Views, 8 Replies
    02-10-2013 11:23 PM
    Hi All,
    This may seem like a silly question, but when you start autocad for the first time, it creates a profile with the default support file search paths. Where does AutoCAD get this from?
    I want to use this for a tool I am creating.
    Please use plain text.
    Distinguished Mentor
    Moshe-A
    Re: Default Support File Search Paths
    02-11-2013 08:05 AM in reply to: BrentBurgess1980
    Brent,
    Command: setvar acadprefix
    will give you the support file search path (it was written to registry when you install AutoCAD)
    clearify what do you mean by tool?
    Moshe
    BrentBurgess1980
    02-11-2013 02:12 PM in reply to: BrentBurgess1980
    The tool has our support paths stored in an XML file that can be used across multiple versions. I thought it would be something very basic like that. I'll give it a crack when I get to work.
    Thanks!
    BrentBurgess1980
    02-11-2013 04:34 PM in reply to: BrentBurgess1980
    Thats the one I am looking for. Do you know how to access the initial value of that?
    Moshe-A
    02-11-2013 10:01 PM in reply to: BrentBurgess1980
    ACADPREFIX contains the initial value plus the paths the user add since the install
    BrentBurgess1980
    02-11-2013 10:17 PM in reply to: Moshe-A
    Is the initial value stored anywhere (ie in the registry)?
    BrentBurgess1980
    02-11-2013 10:18 PM in reply to: Moshe-A
    The only reason I ask is that I need to be able to access it programatically
    dgorsman
    02-12-2013 07:45 AM in reply to: BrentBurgess1980
    I believe the initial paths are partially hard-coded, using some of the installation information as the starting point for the drive and first few folders.  You might be able to pull some of this information out of the registry, but it would be just as easy to hard-code it yourself in the registry or a data file rather than re-calculate it every time.
    Adopt. Adapt. Overcome. Or be overcome.
    Moshe-A
    02-12-2013 09:36 AM in reply to: BrentBurgess1980
    here it is:-
    HKCU\Software\Autodesk\AutoCAD\R1XX.X\ACAD-XXXX:XXX\Profiles\Your Default Profile\General\ACAD
    where XXXX it is version dependet
    in key "Profiles" you should read the (Default) key and have Your Default Profile
    and key ACAD contains what you are after.
    Moshe
