• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    Default Lineweight Changes
    222 Views, 1 Replies
    06-12-2012 08:51 AM
    Using AutoCAD 2011 we always use 0.00 as our default line weight but the default will change to 0.010 with no real pattern. It can be any drawing at any time. We have reset this dozens of times without being able to stop it from reoccurring.
    We are also not able to get line weight to display (yes we check the Lineweight Settings, Display lineweight box) again on random drawings at random times.
    Any ideas??
    John
    John J
    Please use plain text.
    Distinguished Mentor
    Moshe-A
    Re: Default Lineweight Changes
    06-12-2012 09:35 AM in reply to: johnjpowelljr
    John,
    maybe some lisp/application that does that?
    go to other machine with neat installation.
    if you do not have another machine you can logon to your machine with a new user name
    this will create a neat installaion.
    remove any acad.lsp, acaddoc.lsp & *.mnl files from the support file search path.
    Cheers
    Moshe
