• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Active Member
    Default LTSCALE
    208 Views, 6 Replies
    01-29-2013 09:17 AM
    Not sure when this started but we've recently noticed that the default LTSCALE for AutoCAD 2011 is set to 0.5. We recently made the switch from a much older version. This setting does not make sense to me. Why would any setting other than 1.0 be the default. Is this their way of fixing the long time problem that we had to use the "2" versions of the included lintypes in order for them to appear correctly?
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Default LTSCALE
    01-29-2013 09:38 AM in reply to: RobDraw
    LTSCALE variable is stored in the drawing.
    You should check your Template drawing.
    Active Member
    Re: Default LTSCALE
    01-29-2013 09:43 AM in reply to: RobDraw
    Really? (runs off to check) Oh yeah, that is what I am talking about. It is set to 0.5. Now can you answer the question that I posted?
    *Expert Elite*
    rkmcswain
    Re: Default LTSCALE
    01-29-2013 10:17 AM in reply to: RobDraw
    Because maybe that makes the linetypes appear correctly? It's really impossible to answer because everyone will do something a bit different.  Some people may use 1, others 0.5, others 2?
    Ours is set to 0.5 (MSLTSCALE = 1, and PSLTSCALE = 1 also), mainly because we use a lot of custom linetypes that were defined years and years ago and that is the way they were set up.
    Active Member
    Re: Default LTSCALE
    01-29-2013 10:19 AM in reply to: RobDraw
    I can understand changing it from the default to suit your needs but what I don't understand why the default OOTB would be anything other than one.
    *Expert Elite*
    dgorsman
    Re: Default LTSCALE
    01-29-2013 02:59 PM in reply to: RobDraw
    Our OOTB DWT templates for AutoCAD 2011 are all LTSCALE = 1.0 ...
    If you are going to fly by the seat of your pants, expect friction burns.
    Adopt. Adapt. Overcome. Or be overcome.
    Active Member
    Re: Default LTSCALE
    01-29-2013 03:39 PM in reply to: RobDraw
    Further investigation reveals it is 0.5 for vertical products.
