AutoCAD 2010/2011/2012 DWG Format
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Debuging my lisp
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
143 Views, 1 Replies
02-15-2013 01:13 AM
Dear Autocad / Lisp users,
Could somebody please help me with my lisp.
The main goal for the lisp is to correct all colors of the given layers.
And for a few exceptions I want to change the LineType and set them to ByLayer.
It works, most of the time. But it always gives errors.
Couls somebody please have a look?
(defun c:SLC8 () (setq kleur 8) (ChangeLayerColor kleur) ) (defun ChangeLayerColor (kleur / sset ename i) (vl-load-com) (setq i 0) (setq sset (ssget "X" '((8 . "AL*")))) (if sset (repeat (sslength sset) (setq ename (ssname sset i)) (setq i (1+ i)) (vla-put-color (vlax-ename->vla-object ename) kleur) ) ) (setvar "cmdecho" 0) (command "-layer" "unlock" "*" "") (command "layer" "c" "7" "0" "") (command "layer" "c" "7" "*AL70----*" "") (command "layer" "c" "1" "*AL-----_VLOERPLAAT" "") (command "layer" "c" "2" "*AL-----_SPARING" "") (command "layer" "c" "1" "*AL_MAATVOERING" "") (command "layer" "c" "8" "*AL31----*" "") (command "layer" "c" "8" "*AL32----*" "") (command "layer" "c" "8" "*AL21----*" "") (command "layer" "c" "8" "*AL22----*" "") (command "layer" "c" "8" "*AL_31----*" "") (command "layer" "c" "8" "*AL_32----*" "") (command "layer" "c" "8" "*AL_21----*" "") (command "layer" "c" "8" "*AL_22----*" "") (command "layer" "c" "8" "*AT$1A---_TEKST012" "") (command "layer" "c" "8" "*AT$1A---_TEKST018" "") (command "layer" "c" "8" "*AT$1A---_TEKST025" "") (command "layer" "c" "8" "*AT$1A---_TEKST035" "") (command "layer" "c" "8" "*AT$1A---_TEKST050" "") (command "layer" "c" "8" "*AT$1A---_TEKST070" "") (command "layer" "c" "8" "*AT$1A---_TEKST100" "") (command "layer" "c" "1" "ATT012*" "") (command "layer" "c" "1" "ATT018*" "") (command "layer" "c" "2" "ATT025*" "") (command "layer" "c" "3" "ATT035*" "") (command "layer" "c" "4" "ATT050*" "") (command "layer" "c" "5" "ATT070*" "") (command "layer" "c" "6" "ATT100*" "") (command "layer" "c" "254" "00ATT018*" "") (command "layer" "c" "254" "00ATT025*" "") (command "layer" "c" "254" "00ATT035*" "") (command "layer" "c" "254" "00ATT050*" "") (command "layer" "c" "254" "00ATT070*" "") (command "layer" "c" "254" "00ATT100*" "") (command "layer" "c" "254" "00KAD018*" "") (command "layer" "c" "254" "00KAD025*" "") (command "layer" "c" "254" "00KAD035*" "") (command "layer" "c" "254" "00KAD050*" "") (command "layer" "c" "254" "00KAD070*" "") (command "layer" "c" "254" "00KAD100*" "") (command "layer" "c" "7" "0" "") (command "layer" "c" "254" "*BL$2----*" "") (command "layer" "c" "1" "*BL$3----*" "") (command "layer" "c" "254" "*BL$4----*" "") (command "layer" "c" "254" "*BL$5----*" "") (command "layer" "c" "254" "*BL$6----*" "") (command "layer" "c" "8" "*BL$7----*" "") (command "layer" "c" "8" "*BM$7----*" "") (command "layer" "c" "7" "*BL$9----*" "") (command "layer" "c" "7" "*FL80----" "") (command "layer" "c" "8" "*WL905---*" "") (command "layer" "c" "8" "*Xref*" "") (command "layer" "c" "8" "*BL$8----_TEKST*" "") (command "layer" "c" "8" "*BT$8----*" "") (command "SETBYLAYERMODE" "1" "") (command "clayer" "0") (command "SETBYLAYERMODE" "99" "") (command "layer" "c" "8" "*BL$7----*" "Ltype" "DASHDOT" "*BL$7----*" "") (command "._setbylayer" (ssget "X" (list (cons 8 "*BL$7----*"))) "" "yes" "yes") (if (tblsearch "LAYER" "BL$8----") (command "layer" "c" "1" "*BL$8----*" "Plot" "No" "BL$8----*" "" "") (princ "\nLaag BL$8---- Niet kunnen vinden") ) (princ) (if (tblsearch "LAYER" "BL$8----Verdieping") (command "layer" "c" "1" "*BL$8----Verdieping*" "Plot" "No" "*BL$8----Verdieping*" "" "") (princ "\nLaag BL$8----Verdieping Niet kunnen vinden") ) (princ) (if (tblsearch "LAYER" "FL------_BWS30") (progn (command "._setbylayer" (ssget "X" (list (cons 8 "FL------_BWS30"))) "" "yes" "yes" "") (command "layer" "c" "14" "*FL------_BWS30" "") (command "_draworder" (ssget "X" (list (cons 8 "FL------_BWS30"))) "" "Front" "") ) (princ "\nLaag FL------_BWS30 Niet kunnen vinden") ) (princ) (if (tblsearch "LAYER" "FL------_BWS60") (progn (command "._setbylayer" (ssget "X" (list (cons 8 "FL------_BWS60"))) "" "yes" "yes" "") (command "layer" "c" "90" "*FL------_BWS60" "") (command "_draworder" (ssget "X" (list (cons 8 "FL------_BWS60"))) "" "Front" "") ) (princ "\nLaag FL------_BWS60 Niet kunnen vinden") ) (princ) ) (princ)
Anny help will be great.
Thanks in advance.
Michel
Re: Debuging my lisp
Options
- Highlight
- Email to a Friend
02-15-2013 02:51 AM in reply to:
weedseed85
Hello
Please could yo post in THIS forum :
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP
Bye, Patrice
