• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    francisco_bobadilla
    DWG to DGN custom linetypes export
    467 Views, 3 Replies
    09-21-2011 02:28 PM
    One of the features of AutoCAD 2012 is that supports export custom linetypes.  When I try to do the mapping for export, on the right hand column (DGN)  I only get up to 7 linetypes to choose.  Even after clickng on the drawing properties import, it seems like everything gets imported into the left hand column.  Is there somehting I am missing on hoo to use the mapping properly?
    Thanks in advance
    Please use plain text.
    Product Support
    Re: DWG to DGN custom linetypes export
    09-23-2011 06:29 AM in reply to: francisco_bobadilla
    Hi Francisco,
    I think I can reproduce the issue. Here is what I'm doing:
    1. In a new file I create some lines with different linetypes, Export > V8 DGN > Save > OK.
    2. Create new file and Export > V8 DGN > Save > Mapping Setups > New > Continue > Click the DGN icon on top right and browse to the DGN file created in step 1 > Open.
    Expected: linetype properties coming from the file created in item 1 should be added to the DGN list (on the right)
    Result:  linetype properties coming from the file created in item 1 are added to the DWG list (on the left)
    Could you please confirm that this is what you are doing?
    Cheers,
    Luciane
    Luciane Conceição
    Product Support Specialist
    francisco_bobadilla
    09-23-2011 07:58 AM in reply to: luconceicao
    Hi Luciane,
    Yes this exactly what is happening.  The imported linetypes don't show up on the left (DGN) column as expected.  Is this a known bug?
    Your help is much appreciated.
    Product Support
    09-23-2011 08:30 AM in reply to: francisco_bobadilla
    Hi Francisco,
    I think that you are reporting this for the first time.
    I will forward this information to our development team, thank you for letting us know.
    Cheers,
    Luciane
